MPX 2.0 Presenter Plug-in
Aug 11th, 2008
I have a customer where we have just installed MPX 2.0.3.35. Because of security requirements, the customer's desktops have been secured so that the general user does not have rights to install the Presenter plug-in.
They have been able to push the Outlook plug-in because they can push patches as long as they can be run silently with no input from the user. The outlook plug has a /admin /silent switch that can be used to install on a pc.
Is there something similar for the presenter plug-in?
thanks.
