ASA-5505 ezvpn client with multiple inside networks?
Aug 11th, 2008
Can an ASA-5505 be a ezvpn client with multiple inside networks? [I have seen commands for an 871 to do this but we have an asa-5505 at the remote.]
If not, any suggestions on how to route the internal networks and all internet over the vpn tunnel to an IOS vpn server.
Marwan ALshawi Mon, 08/11/2008 - 19:07
asa can be ezvpn client
and on the router the server side of the vpn
u need to add RRI
reverse route injuction on the dynamic-map
One key component of routing in a VPN deployment is Reverse Route Injection (RRI). RRI places dynamic entries for remote networks or VPN clients in the routing table of a VPN gateway. These routes are useful to the device on which they are installed, as well as to other devices in the network because routes installed by RRI can be redistributed through a routing protocol such as EIGRP or OSPF
in this case when the ezvpn client connect its route will be added to the server vpn
good luck
please, if helpful rate
