Hide / Dynamic Inbound PAT/NAT
Answered Question
Aug 11th, 2008
Does an ASA support hide / dynamic PAT/NAT from the outside interface to the inside interface and how is it configured?
please configure
"no nat-control"
on this ASA, or
give the inside -> outside direction a nat translation.
With nat-control enabled the inside hosts require a nat translation once nat has been configured when going from a high security to lower security interface.
In your case you can optionally leave nat-control enabled, and configure a static to itself or use nat 0
option 1.
static to itself
static (inside, outside) 192.168.1.0 192.168.1.0 255.255.255.0
option 2.
nat 0
nat (inside) 0 access-list nonat
access-list nonat extended permit ip 192.168.1.0 255.255.255.0 172.16.0.0 255.255.0.0
-Joe
"Why so serious"
Overall Rating: 5 (1 ratings)
dhananjoy chowdhury Mon, 08/11/2008 - 20:45
You can do a port redirection from outside to Inside or DMZ
If the want to achieve this :
- traffic coming to Outside IP A.B.C.D on port 80 should be redirected to the inside IP 192.168.1.10 on port 80
- traffic coming to Outside IP A.B.C.D on port 443 should be redirected to the inside IP 192.168.1.20 on port 443
the use these commands :-
static (Inside,Outside) tcp A.B.C.D 80 192.168.1.10 80
static (Inside,Outside) tcp A.B.C.D 443 192.168.1.20 443
dave-taylor Mon, 08/11/2008 - 20:50
Thanks for the reply, not exactly what I want. What I'm trying to do is changethe source address destine for A.B.C.D to an internally routed address so that I don't have to route external addresses on my internal network.
x.x.x.x -> a.b.c.d (firewall) y.y.y.y -> a.b.c.d
all too easy.
start with this concept.
ciscoasa# show run | inc nat|global
global (inside) 2 interface
nat (outside) 2 0.0.0.0 0.0.0.0 outside
Here we will nat the outside address (in this case ANY will be natted when source is outside)
we are natting to the inside interface ip.
you can do this in your environment if you want a friendly ip instead.
global (inside) 2 10.7.7.7
then on the router facing the asa inside interface
ip route 10.7.7.7 255.255.255
-Joe
dave-taylor Mon, 08/11/2008 - 21:54
Thanks Joe.
That was pretty close to the way I configured it on the ASA (didn't have "outside" at the end of the nat statement originally) but it still does not work.
%ASA-6-199002: Startup completed. Beginning operation.
%ASA-5-502103: User priv level changed: Uname: enable_15 From: 1 To: 15
%ASA-7-111009: User 'enable_15' executed cmd: show logging
%ASA-7-609001: Built local-host outside:172.16.0.50
%ASA-7-609001: Built local-host inside:192.168.1.1
%ASA-6-305011: Built dynamic TCP translation from outside:172.16.0.50/1041 to inside:192.168.1.2/1024
%ASA-3-305005: No translation group found for tcp src outside:172.16.0.50/1041 dst inside:192.168.1.1/2
%ASA-7-609002: Teardown local-host inside:192.168.1.1 duration 0:00:00
Lab-ASA#
Lab-ASA# show run
: Saved
ASA Version 7.2(2)
hostname Lab-ASA
enable password xxx
names
interface Vlan1
nameif inside
security-level 100
ip address 192.168.1.254 255.255.255.0
interface Vlan2
nameif outside
security-level 0
ip address 172.16.0.1 255.255.255.0
interface Ethernet0/0
switchport access vlan 2
interface Ethernet0/1
interface Ethernet0/2
interface Ethernet0/3
interface Ethernet0/4
interface Ethernet0/5
interface Ethernet0/6
interface Ethernet0/7
passwd xxx
ftp mode passive
access-list Out-In extended permit tcp 172.16.0.0 255.255.0.0 192.168.1.0 255.255.255.0
pager lines 24
logging enable
logging buffered debugging
logging asdm informational
mtu inside 1500
mtu outside 1500
icmp unreachable rate-limit 1 burst-size 1
no asdm history enable
arp timeout 14400
nat-control
global (inside) 2 192.168.1.2
nat (outside) 2 172.16.0.0 255.255.255.0 outside
access-group Out-In in interface outside
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout uauth 0:05:00 absolute
http server enable
http 192.168.1.0 255.255.255.0 inside
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
telnet timeout 5
ssh timeout 5
console timeout 0
dhcpd auto_config outside
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
message-length maximum 512
policy-map global_policy
class inspection_default
inspect ftp
inspect h323 h225
inspect h323 ras
inspect rsh
inspect rtsp
inspect esmtp
inspect sqlnet
inspect skinny
inspect sunrpc
inspect xdmcp
inspect sip
inspect netbios
inspect tftp
service-policy global_policy global
prompt hostname context
Cryptochecksum:xxx
: end
Lab-ASA#
Correct Answer
please configure
"no nat-control"
on this ASA, or
option 1.
static to itself
option 2.
nat 0
-Joe
"Why so serious"
