LMS 3.0.1 Topology Services with CallManager 4.2
Aug 11th, 2008
I have added our Cisco CallManager server 4.2 on LMS using CS. I have successfully discovered all ip phones in a cluster. Slight problem, the topology is showing the CCM server as an application server instead of the Cisco Callmanager icon. I know its a very small issue but I'm trailing this and at the same time proposing the solution to my manager.
Is this a task I have to download from cisco.com? The icon "Cisco CallManager" is not presented on the Help -> Legend menu under Topology Service.
Joe Clarke Tue, 08/12/2008 - 08:14
This is how a Call Manager is supposed to look on the Topology Map. It sounds like Campus is working as designed for you.
