failover with HSRP and BGP or any other routing protocol ?
Answered Question
Aug 11th, 2008
hi,
we have a site with to connections in with 2 router for failover. We would like to do a more automatic failover when one of the routers fails.
This is what I have come up with so far...
http://home.netpower.no/paal/hsrp/hsrp-bgp.jpg
HSRP on the LAN, but I'm not sure if BGP is the right thing to use on the WAN(ATM) to our HQ Main Router.
I find BGP a bit complex to configure, but it's doable.
OSPF is easy to set up in VRF's, but how is BGP to configure in VRFs ?
any suggestions or tips ?
Correct Answer by Giuseppe Larosa about 8 years 8 months ago
Hello Paal,
It's even easier:
just create the address-family ipv4 vrf VRF_NOC
router bgp xxx
adress-family ipv4 vrf VRF_NOC
neigh y.y.y.y remote-as YYY
neigh y.y.y.y activate
red con
red static
no sync
no auto-sum
Hope to help
Giuseppe
Overall Rating: 4 (1 ratings)
Correct Answer
Giuseppe Larosa Tue, 08/12/2008 - 04:42
  • Hall of Fame,
    Founding Member
Hello Paal,
It's even easier:
router bgp xxx
red con
red static
no sync
no auto-sum
Hope to help
Giuseppe
