CSS - https on another port no
naive.naive
Need to load balance a SSL on a different port no (terminate at the server, hence no SSL module exist on the CSS) Below are the config, do I need to add additional config, i need it to be access via https://2.2.2.2/f1
service f3_https
protocol tcp
port 4443
keepalive port 4443
ip address 1.1.1.2
string f1
keepalive type tcp
active
service f4_https
protocol tcp
port 4443
keepalive port 4443
ip address 1.1.1.5
string f1
keepalive type tcp
active
content f1-4443
protocol tcp
vip address 2.2.2.2
port 4443
advanced-balance arrowpoint-cookie
add service f3_https
add service f4_https
arrowpoint-cookie name f1
active
Any help please ...
Thanks..
Gilles Dufour
you can't use "advanced-balance arrowpoint-cookie" with encrypted data.
The cookie is part of the http header which is encrypted.
Gilles.
gilles,
how about other config?
do i need to add additional config to make the service to be accessed via https??
thanks..
The rest of the config is correct.
Gilles.
