Giuseppe Larosa Tue, 08/12/2008 - 00:23
  • Hall of Fame,
    Founding Member
Hello Jefferson,
you can filter the sh ip bgp output with a route-map
sh ip bgp route-map loc-pref-200
where the route-map has been defiend as:
match local-preference 200
For weight I don't know it is not a match option in a route-map
Hope to help
Giuseppe
Giuseppe Larosa Tue, 08/12/2008 - 00:36
  • Hall of Fame,
    Founding Member
Hello Jefferson,
as far as I know the regexp will look at the BGP AS path attribute and local-preference and weight are different BGP attributes
see:
#sh ip bgp regexp ?
LINE A regular-expression to match BGP AS paths. Use "ctrl-v ?" to enter "?"
So I think you cannot find loc-pref or weight inside AS path
Hope to help
Giuseppe
rajivrajan1 Tue, 08/12/2008 - 02:40
  • Bronze, 100 points or more
hi there,
It's difficult to match exatly your requirement.Still u can filter out by using sh ip bgp | include or exclude or using reg expression after include.
leopastor Wed, 10/15/2008 - 14:46
The Weight atribute is local to a router, can be applied only on incoming updates, and is never propagated.
Therefore, you will not be able to match based on it!
johnlloyd_13 Tue, 08/12/2008 - 03:46
  • Blue, 1500 points or more
if you used route maps, yes you could see them. use the show route-map command. you will see the associated attribute used in your filtering.
leopastor Wed, 10/15/2008 - 14:49
You CANNOT *match* based on Weight, you can only *set* it!
