Logs files in Ciscoworks.
Answered Question
Aug 12th, 2008
Good Morning,
THe following log files have exceeded the recommended size:
dmgtDbg.log
stdout.log
syslog.log
CSDiscovery.log
CVDeviceSelector.log
I am trying to get these log file to write to a new one when the log file reaches it recommended size. On the web, the reference a tool called LOGROT. I cannot find this tool on the servers.
Any ideas anyone?
Thanks a million
Anthony.
Correct Answer by Martin Ermel about 8 years 10 months ago
Hi Anthony,
that is OK. The value in the file is in Bytes whereas the GUI shows KBytes. With 1KByte being 1024 Byte you get the following calculation:
1024 Byte x 1024 = 1048576 Byte
1024 BYte x 1048576 = 1073741824 Byte
or generally speaking
1024 Byte x Recommended Size Limit (KByte) = Value in logstat.conf (Byte)
The log files being red exceed the Recommended Size Limt.
For dmgtDbg.log you could enter a recommende Size Limit of 300 000 KByte which would be
1024 x 300 000 = 30307200000
in logstat.conf
these settings are made in
NMSROOT/conf/logstat.conf
the values in this file are in bytes (with 1Kbyte = 1024 bytes);
just change the values and save the file; any logfile using more then 90% of the 'Recommended Size Limit' will be in red letters.
to see the changes, open Common Service > Server > Reports > Log File Status ==> Generate Report
per default it took 5 min to see the update in the portal view ('Log Space Usage').
Correct Answer by Sven Hruza about 8 years 10 months ago
Hi!
I forgot something...sry!
You have to create a job which execute logrot.pl once a day or something.
I created a file named logrot.bat and put the string into to start logrot.pl
\MSROOT\CSCOpx\bin\perl \MSROOT\CSCOpx\bin\logrot.pl -v
With the scheduler you can plan the job.
Sven
Okay, I try to explain...
Start logrot with
\MSROOT\bin>perl \MSROOT\bin\logrot.pl -c
Then you get the following:
Logrot Configuration Menu
1. Edit variables
2. Edit log files
3. Quit and save changes
4. Quit without saving changes
Enter option:
There you can configure the logfiles under the option 2.
Under option 1 you can edit the path where you will save the old logfiles.
Enter 2.
Warning: No logfiles found.
a. Add logfile(s)
d. Delete logfile(s)
q. Go back
Enter option or logfile number to edit:
To add a new logfile enter a.
Then follow the configuration:
Enter logfile path []: \MSROOT\log\CSDiscovery.log
Enter number of archives to keep [0]: x
Enter maximum file size (in kilobytes) [1024]: xy
Compression extension (Z,bz2,gz):
Number Logfile Name Number of Archives Max Size Compress
1. \MSROOT\log\CSDiscovery.log x xy
a. Add logfile(s)
q. Go back
Good luck ;)
Sven
Overall Rating: 4.8 (8 ratings)
Sven Hruza Tue, 08/12/2008 - 01:43
  • Bronze, 100 points or more
Hi!
I think you can use the perl-script C:\Program Files\CSCOpx\bin\logrot.pl for backup logfiles.
To configure it use
C:\Progra~1\CSCOpx\bin\perl C:\Progra~1\CSCOpx\bin\logrot.pl -c
Sven
Anthony O'Reilly Tue, 08/12/2008 - 04:43
Hi Sven,
Many thanks for your response.
I opened up thelogot.pl -c as you said, where in here do you locate the log file I want to configure.
To be honest, I'm lost.
Anthony
Correct Answer
Sven Hruza Tue, 08/12/2008 - 05:01
Start logrot with
1. Edit variables
2. Edit log files
Enter option:
Enter 2.
a. Add logfile(s)
q. Go back
a. Add logfile(s)
q. Go back
Good luck ;)
Sven
Anthony O'Reilly Tue, 08/12/2008 - 05:19
Many many thanks Sven,
I finally got it working.
One more question, do I need to restart services to get this to work.
Anthony
Anthony O'Reilly Mon, 08/25/2008 - 00:56
Hi Sven,
THe Ciscowork server is still stating that the logs are too big, do I need to restart logrot or any other service.
Your help will be much appreciated.
Anthony.
Correct Answer
Sven Hruza Mon, 08/25/2008 - 01:03
Hi!
Sven
Anthony O'Reilly Wed, 08/27/2008 - 23:49
Hi Sven,
Just more one thing.
I ran the scheduled job and it ran fine. THe warnings on the system page are gong e but on the On the Log Space Usage section it still says the log file bigger than the recommended size.
How do you resolve this?
Thanks again,
Anthony.
Anthony O'Reilly Wed, 08/27/2008 - 23:43
Hi Sven,
Thanks again,
Anthony.
Correct Answer
Martin Ermel Thu, 08/28/2008 - 04:33
  • Blue, 1500 points or more
Anthony O'Reilly Fri, 08/29/2008 - 00:54
Hi Martin,
I have attached the screen grab from Ciscowork and the conf file for the log settings. I have also setup logrot.pl as advised by Sven earlier on in the thread.
Any more ideas.
Much appreciated.
Anthony.
Correct Answer
Martin Ermel Fri, 08/29/2008 - 04:55
Hi Anthony,
in logstat.conf
Martin Ermel Fri, 08/29/2008 - 07:11
Hi Anthony,
I think you are right and the realy hard thing with this calculation is to get the result of 30307200000 if you have 1024 * 300 000
surely it is 1024 * 300 000 = 307200000
I would say the first was a typo ...
otherwise it would be a little embarrasing :-)
Sec IT Mon, 06/29/2009 - 03:20
Dear All,
it was extremely helpfull..I face the same problem but got answer in the last conversation as to change the value in logstat.conf, logstat.old.conf, logstat.orig etc.
No need to use perl command and get the command prompt hung.
issue is resolved..
Anyway thanks to the team for posting such a very good topic.
regards
Rajesh P
