08-12-2008 12:21 AM - edited 07-03-2021 04:18 PM
HI all,
i need advise on how to upgrade the ios for wlc 526 with out using the cca.
using cli ?
cca need ios 4.2 and above and my ios is 4.0.
thanks
08-12-2008 04:36 AM
I havent tried this personally but I think it will work. Go to the gui on the 526 just like you would a 2106. Go to commands, download code, and then upgrade the code via a tftp server that supports 32mb files or larger. I think it works in the 526 but I'm not sure.
08-12-2008 05:31 AM
he is correct..... you can use the GUI on the WLC but not the CLI....the CLI on the WLC526 is locked out (this is different from the enterprise controllers)
