Security-Context and Site-to-Site VPN
Aug 12th, 2008
I've configured multiple security contexts with asa 5550. Now I want to use for one context an IPSEC-Tunnel over the internet to connect a remote-site.(VPN Site-to-Site)
Is it possible to use overlapping IP-Ranges and can I locial seperate the VPN's ? I need the same functionality as VRF-Lite/IPSEC with an IOS Router.
Overall Rating: 5 (1 ratings)
Daniel Voicu Tue, 08/12/2008 - 05:24
  • Silver, 250 points or more
You might want to have a look on the documentation again.
If you configure multicontext, you cannot use ISPEC or SSL anymore, along with some other features:
Unsupported Features
Multiple context mode does not support the following features:
•Dynamic routing protocols
Security contexts support only static routes. You cannot enable OSPF, RIP, or EIGRP in multiple context mode.
•VPN
•Multicast routing. Multicast bridging is supported.
•Threat Detection
http://www.cisco.com/en/US/docs/security/asa/asa80/configuration/guide/contexts.html
Please rate if this helped.
Daniel
