CCNA Expires...i want to go for CCSP
Aug 12th, 2008
My CCNA expires in Sept2006
Now i want to go for CCSP, Can i go directly to the 5 papers option or i have to retake the CCNA security and then do the 4paper option
plz reply soon because i have prepared SND and want to do it at earliest.
Waiting
MWA
rangaabey Tue, 08/12/2008 - 02:20
i) If you do SND you will have to recertify for your CCNA. Then you will be able to take other 4 modules in CCSP.
ii) But it is better for you to take CCNA -Security give up the SND option and follow the new CCSP curriculum . But this will be available from 29th Aug.
For references abour dead lines go to
http://www.cisco.com/web/learning/le3/le2/le37/le54/learning_certification_type_home.html
ahsan9212 Tue, 08/12/2008 - 02:34
so expired CCNA + SND will not give me the option with the track, without giving CCNA again ?
Actually i don't want to waste more amount on CCNA again, instead i want to use it for CCSP papers.
Did it means that i have to repeat CCNA in any case ?
