Update UCCM 5.1.3
Aug 12th, 2008
How i can update my UCCM?
Just now i have 5.1.3.1000-12 ver software
Where i can see - it's las update or not?
And where i can download update if they essential..
I find only this linc http://tools.cisco.com/support/downloads/go/ImageList.x?relVer=5.1(3c)&mdfid=280735907&sftType=Unified+Communications+Manager+Updates&optPlat=&nodecount=2&edesignator=null&modelName=Cisco+Unified+Communications+Manager+Version+5.1&treeMdfId=278875240&treeName=Voice+and+Unified+Communications&modifmdfid=null&imname=&hybrid=Y&imst=N&lr=Y
But it's image above 1 gigabite...
I think it's not update - it's new version..
Chris Deren Tue, 08/12/2008 - 06:51
  • Hall of Fame,
  • Cisco Designated VIP,
    2017 IP Telephony, Contact Center, Unified Communications
It is an update :-) It's the latest revision of 5.1.3 code (5.1.3.4000-4).
HTH, please rate all useful posts!
Chris
Jaime Valencia Tue, 08/12/2008 - 07:50
  • Cisco Employee,
  • Hall of Fame,
    2011
just to add some info, usually SRs and ES are around 1.4 gigs for 5.x and 6.x versions
java
if this helps, please rate
vadim.kharchenko Tue, 08/19/2008 - 05:02
Please help - i download this file - cisco--ipt--k9--patch5.1.3.4000--4.tar.gz.sgn
If i read this file to disk or to sftp
and try to install from "software upgrade" CCM cannot see this file :(
Chris Deren Tue, 08/19/2008 - 15:45
  • Hall of Fame,
What message are you getting? Is CM saying that there are no newer versions available? If so are you specifying the correct path for te file? Make sure that the file downloaded with the .tar.gz.sgn extension, there was a bug that it would miss the .sgn suffix.
Chris
vadim.kharchenko Wed, 08/20/2008 - 02:48
If i try to upgrade from dvd or sftp i see nex message
"The directory was located and searched but no valid options or upgrades were available. Note, a machine cannot be downgraded so option and upgrade files for previous releases were ignored."
Full file name "cisco--ipt--k9--patch5.1.3.4000--4.tar.gz.sgn"
I dont know why CM cann't see this patch :(
neil.woolloff Wed, 02/09/2011 - 09:20
Did you get a fix for this?
I ask as am having same issue upgrading from 5.0.4 to 5.1.3f.
publisher upgraded all ok with no issues
subscriber is giving me same error message.  annoying part: it can see latest dial plan in same folder so i know credentials are all good.
Also get same error if i try to apply from a dvd.
pointers appreciated.
NeilW
