Extension Mobility Authentication Problems
I have CallManager 4.2(3) integrated with Active Directory. When logging onto EM with an old pin the message authentication error appears. When the pin is changed via CCMAdmin and logging onto EM the message error 23 is seen. Error 23 implies the userid does not exist, clearly this is wrong as it does. When the old pin is re-tried I still see the authentication error message. It appears that it may be trying to authenticate in two different places. I have checked the registry on CallManager for the directory and this is set to true. EM was working previously. I have tried new accounts and resetting TomCat but to no avail. Any assistance would be gladly appreciated.
Jaime Valencia Tue, 08/12/2008 - 07:49
  • Cisco Employee,
  • Hall of Fame,
    2011
i would suggest to re-run the EM plugin. sounds like you ran the tool twice and you're not looking at the right directory or hoteling profile
java
if this helps, please rate
Jaime Valencia Wed, 08/13/2008 - 06:45
  • Cisco Employee,
  • Hall of Fame,
    2011
well, yes i mean AD plugin because there is no EM plugin =)
EM is a service you configure, not a plugin
java
