08-12-2008 03:12 AM - edited 03-18-2019 09:27 PM
Hi!
I'm having some problems intalling CCX on a server. The first time it went fine but I decided to repeat the whole process and know the following error message appears when I insert the CCX DVD:
"The SQL2K cannot be instlled on this machine as this machine doesn't have a CRS Instance Installed.
Please run CRS setup on this machine before running SQL2K setup"
This after I re-image the server using the Windows 2003.1.2 dvd given by Cisco.
Ana
Solved! Go to Solution.
08-12-2008 06:38 AM
Are you following the proper steps? It appears that you are attempting to install sql server or MSDE before running the install media.
Chris
08-12-2008 06:38 AM
Chris
08-13-2008 01:03 AM
Hi!
You're right. I couldn't find the CRS Installer DVD so I was using the SQL2K installer by mistake.
Thanks for your help.
Ana
