How many files can ACS Reports manage?
Aug 12th, 2008
Couple weeks ago we need to move some ACS log files to another folder because volume was full where files are stored.
I solved the space volume issue and moved back files to original folder.
After that I can't see all files available at ACS Reports and Activity.
We need retain 540 days of logging report on ACS.
Can ACS manage all these files?
purohit_810 Tue, 08/12/2008 - 05:12
IN system configuration, Logging.. Adjust an option " Manage Directory ".
You will be fine to save logging 540 days.
Dharmesh Purohit
Marcelo Martins... Tue, 08/12/2008 - 05:34
Hi Dharmesh,
I disabled and re-enabled this option on Logging Configuration, but I still can not see some files by ACS web interface.
All files are available in logs folder.
I checked file permissions and all of them have same setting.
