Spectrum Expert Software does not Start
Aug 12th, 2008
i have installed the Spectrum Expert Software on my Dell Latidude D520 Notebook.
The Card ist correct installed to.
(Control Panel --> System --> Hardware)
But if started the software the software hang up and do nothing.
I can stop the software with taskmanager only.
What the Problem ?
dennischolmes Tue, 08/12/2008 - 05:19
Try disabling the onboard card first to see if there is an interupt issue. Also, make sure you have bluetooth disabled if it exists on that model of Dell.
KUMAident Tue, 08/12/2008 - 05:33
Yes, the BT device and the wiresless build in card are disabled.
KUMAident Tue, 09/09/2008 - 05:20
Problem and Solution found now.
On my Laptop the COMODO Personal Firewall are installed Vers
This Software are the Problem.
After remove the Software the Spectrum Expert start without problems and work fine.
Best Regards
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
