2611XM + VWIC2-2MFT-T1/E1
Answered Question
Aug 12th, 2008
Hi there !
I have a 2611XM in a branch, with some gateways (only 8 ports)... I'd like to change it to a E1 .. how can I check if this router supports this interface ?
I looked for this router in Cisco Configuration Tool.. but it's not there ...
Any help ?
Thanks.
Andrei.
Correct Answer by Collin Clark about 8 years 8 months ago
It's usually easier to look up the card and see if it's supported in the router. Here's the data sheet for the VWIC (it is supported w/IOS 12.3(14)T).
http://www.cisco.com/en/US/prod/collateral/routers/ps5855/product_data_sheet0900aecd8028d2db.html
Hope that helps.
Correct Answer by purohit_810 about 8 years 8 months ago
Overall Rating: 5 (2 ratings)
