dtmf on sip trunk to voip company
cmelbourne
I have a sip trunk to magnet broadband and dtmf is not working outbound or inbound.
anyone ideas anyone
13 Replies 13
Ayodeji Okanlawon
Chris,
Can you post the config on your voip dial-peer that connects to your service provider here
Please rate all useful posts
see below.
also tried other dtmr relay protocols as well
they said it was rfc2833 which is rtp-nte
dial-peer voice 200 voip
description SIP TRUNK
translation-profile incoming prefix
translation-profile outgoing out
preference 7
destination-pattern .T
voice-class codec 1
session protocol sipv2
session target dns:voip.magnetnetworks.com:5060
incoming called-number .
dtmf-relay rtp-nte
no vad
Ok..
On your Sip trunk, you need to assign it to a MRGL that has a software MTP in its MRG.
Is this CCM or CCME...The above is for CCM, if its CCME, then you will need hardware MTP
Chris Deren
You will require an MTP for DTMF with SIP, simply create MTPs and on the SIP trunk check the "require MTP" checkbox.
Chris
do you have a config for this?
this is call manager express
Here is a link to a tech note that discusses CME and dtmf relay support - they talk about sip and sccp phones, but they also have a SIP trunk in their sample config, with comments:
http://www.cisco.com/en/US/products/sw/voicesw/ps4625/products_configuration_example09186a00808f9666.shtml
Mary Beth
do you have a config template for this so i can look at it please?
still did not work.
has anyone got dtmf working over sip trunks to a voip company?
please post your ENTIRE conifg and sh ver. Alos sh sccp all
Chad
see below
#sh ver
Cisco IOS Software, 2800 Software (C2800NM-SPSERVICESK9-M), Version 12.4(9)T7, R
ELEASE SOFTWARE (fc3)
Copyright (c) 1986-2008 by Cisco Systems, Inc.
Compiled Thu 10-Jan-08 16:35 by prod_rel_team
ROM: System Bootstrap, Version 12.4(13r)T, RELEASE SOFTWARE (fc1)
cma-cgm uptime is 22 hours, 46 minutes
System restarted at 14:17:17 GMT Wed Aug 13 2008
System image file is "flash:c2800nm-spservicesk9-mz.124-9.T7.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco 2811 (revision 53.51) with 249856K/12288K bytes of memory.
Processor board ID FCZ122970FY
2 FastEthernet interfaces
1 terminal line
1 Channelized (E1 or T1)/PRI port
4 Voice FXS interfaces
1 cisco service engine(s)
DRAM configuration is 64 bits wide with parity enabled.
239K bytes of non-volatile configuration memory.
125440K bytes of ATA CompactFlash (Read/Write)
Configuration register is 0x4102
sh sccp all
SCCP Admin State: DOWN
Gateway IP Address: 0.0.0.0, Port Number: 0
IP Precedence: 5
User Masked Codec list: None
There is no CCM group configured.
Total number of active session(s) 0, and connection(s) 0
Total number of active session(s) 0, connection(s) 0, and callegs 0
SCCP Application Service(s) Statistics Summary:
Total Conferencing Sessions: 0, Connections: 0
Total Transcoding Sessions: 0, Connections: 0
Total MTP Sessions: 0, Connections: 0
Total ALG-Phone Sessions: 0, Connections: 0
Total BRI-Phone Sessions: 0, Connections: 0
Total SCCP Sessions: 0, Connections: 0
Total active sessions 0, connections 0, rsvp sessions 0
redirect ip2ip
b2bua
session transport udp
dtmf-relay sip-notify rtp-nte
codec g711ulaw
fax rate disable
fax protocol pass-through g711ulaw
clid network-number 016522020
dial-peer voice 40 voip
description *AUTOATTENDANT*
destination-pattern 016522020
b2bua
session target ipv4:10.17.49.5
codec g711ulaw
no vad
Not sure if this will help but try addig the following to your SIP dial peer
rtp payload-type cisco-codec-fax-ack 114
rtp payload-type cisco-codec-fax-ind 113
rtp payload-type nte 98
voice-class sip dtmf-relay force rtp-nte
wil give that a go.
do you think this could resolve a fax issue we have over the sip trunk as well. basically we can dial into the fax but not send a fax. the voice translation rule is ok as i tested this. i can see the voice call from the fax machine leave the system as well over the dial peer
