IP MTU on both IPsec /GRE VPN
Aug 12th, 2008
Can you share the best practice to configure the ip mtu setting on such a vpn connection? Thank you.
ciscocow Tue, 08/12/2008 - 10:45
For GRE: The ip mtu command needs to be put on the GRE tunnel and the physical interface.
For IPSEC: It would be the physical interface as you do not have a logical interface in which to place that command.
Also do not forget to add the "ip tcp adjust-mss" command, or you will have alot of headaches.
drnteam Tue, 08/12/2008 - 21:14
I am using the IPSEC tunnel but enabled the IP mtu under tunnel. Is it a good practice to enable IP mtu under tunnel only. Also what exactly the "ip tcp adjust-mss" will do?
Please explain.
Thanks in advance.
pmpesha Wed, 08/13/2008 - 05:29
Thank you ciscocow. I do have tihe ip mtu configured on my GRE tunnels, with the ip tcp adjust-mass. Mu Ipsec interfaces hare using the defalut value (1500), I do not have the ip tcp adjust-mass configured. When I do perform the test on my IPsec interfaces I do get an error about failing MTU size and Do not Fragment bit, any ideas?
