Upgrading to IOS firewall
Aug 12th, 2008
folks
i have a HSRP router pair on my perimeter which i'm going to upgrade to a firewall pair so i can take advantage of active/standby and for better management
has anyone enable the firewall on a working router before?
will i lose any of my config?
thanks to anyone taking the time to reply
Daniel Voicu Tue, 08/12/2008 - 09:33
  • Silver, 250 points or more
Normally, the IOS upgrade will leave your config intact.
The hard part will be implementing the firewall rules.
I suggest you first deploy them on secondary HSRP router and test them with two computers, one on each side ( both pointing to the physical IP of the secondary router).
When the rules are ready, copy them to the primary.
Please rate if this helped.
Cheers,
Daniel
