What is the best solution for CCM 4.1 (6) trunk?
Aug 12th, 2008
How can I trunk CCM_A cluster to other CCM_B cluster? Is SIP trunk good? Or I should use something like Inter-cluster trunk?
What is the best solution?
The bandwidth from side A to Side B is about 30 Mbps.
Overall Rating: 2 (1 ratings)
Jaime Valencia Tue, 08/12/2008 - 07:38
  • Cisco Employee,
  • Hall of Fame,
    2011
both would work but an ICT non-GK controlled is the standard way to do this and is easier to troubleshoot than a SIP trunk if needed.
java
if this helps, please rate
webstd.design Tue, 08/12/2008 - 11:27
And if this trunk will not be permanent? I purpose that there will be a lot of situations of make this trunk down. In this situation which solution is better?
