HELP QUICK! 6500 reload
Aug 12th, 2008
I am upgrading my sup32 from Hyrbrid to native, and am following the guide:
http://www.cisco.com/en/US/products/hw/switches/ps708/products_tech_note09186a008015bfa6.shtml#conv_32
When i issue the reload command after changing the config register value to 0x0 i get the following message:
Reload to tge ROM Monitor only allowed from console line unless the conf register boot bits are non zero.
How do I get the router to reload in monitor mode?
Help well rated
rkhalil Tue, 08/12/2008 - 07:49
  • Bronze, 100 points or more
put confreg 0x2102
or use break sequence for rommon and put confreg 0x2102
Raul
(Please rate helpful posts)
gavin.mckee Tue, 08/12/2008 - 07:56
I did this and it broke out of session 16
now I can't get on to the MSFC at all
when I do session 16 I get unable to tunnel to session 16
Am i in big trouble now?
rkhalil Tue, 08/12/2008 - 10:29
enter from console of msfc and review your config.
