[email protected]/E1
Richard Burts Tue, 08/12/2008 - 08:13
I wonder if the issue that the card may require a certain version of code. What version of code are you running in your 2821?
garytayl Tue, 08/12/2008 - 08:15
After the card type command, did you use: Router(config)# controller t1
and then you specify the framing and linecode and is still not showing up in the config?
Don't forget to issue no shut at the end in order to activate the controller.
