Allowing RDP traffic
Aug 12th, 2008
I am using a Cisco PIX 515e with three interfaces outside, inside, DMZ. I am providing VPN access via the pix the issue I am having is when I connect to my network via VPN I cannot RDP to servers in my DMZ. I can RDP to servers on my internal network.
When I connect to the VPN I get an IP address of 192.168.10.x, My inside IP addresses are 192.168.1.x my DMZ addresses are 192.168.5.x.
I created an ACL to allow traffic over port 3389 (RDP) from to (server in my dmz) the acl looks like:
access-list vpn_access_dmz permit tcp host host eq 3389
The issue is I am not sure which interface this access list should be applied to (inside, outside, dmz?) Does anyone have an idea or can give me some pointers?
Thanks for any help!
acomiskey Tue, 08/12/2008 - 09:01
Don't worry about that access list, you shouldn't need it.
You most likely need to add nat exemption for the dmz hosts.
access-list DMZ_nat0_outbound extended permit ip
nat (DMZ) 0 access-list DMZ_nat0_outbound
kcgpassport Tue, 08/12/2008 - 09:48
Thanks for the help, in your access-list command what is the 'extended' command for?
acomiskey Tue, 08/12/2008 - 10:00
Sorry, I had ASA on the brain, you don't need "extended".
access-list DMZ_nat0_outbound permit ip
