Accessing a Catalyst 3750
Aug 12th, 2008
I'm trying to mapp out a network and I have a catalyst switch I need to access. The only information I have is that it is not ip addressed. It is accessed through port 49 VL220 I have the password but don't know how to interface with it with out a ip. I could use a consul cable but have been told I should be a to access through the port using ethernet
cowetacoit Tue, 08/12/2008 - 10:04
If it doesn't have an IP address then you can't manage it by telnet. You'll have to console into it.
Sebastian Helmer Tue, 08/12/2008 - 10:15
Yes, without IP no telnet.
If you are not sure, you can check if he really have no IP , but only if cdp is enable.
"show cdp neighbors detail"
