catalyst Ws-C6500-L
Giuseppe Larosa Tue, 08/12/2008 - 10:46
  • Hall of Fame,
    Founding Member
Hello Frank,
try to use the following command
conf t
power enable module
this should provide power to the module in slot slot_number
Hope to help
Giuseppe
Giuseppe Larosa Wed, 08/13/2008 - 04:38
  • Hall of Fame,
    Founding Member
Hello Franck,
sorry it was even easier ...
when you add a network module in a never used slot you need to enable the new module's ports with no shut on all the ports you want to use
do
int gi7/1
no sh
to get at least a L1 link
Hope to help
Giuseppe
Giuseppe Larosa Wed, 08/13/2008 - 08:21
  • Hall of Fame,
    Founding Member
Hello Franck
in order to connect a PC and to provide ip connectivity:
you need to put the port in switchport mode and in an access vlan that has L3 services:
int gi7/1
no shut
>>switchport
switchport mode access
swtichport access vlan 130
Be aware in a C6500 default port config is to be a routed port (to have an ip address on it).
This is a different behaviour then other multilayer switches where the port is L2 by default.
you can check with:
sh int gi7/1 switchport
where 130 stays for an access vlan
or also vlan 1 can be used of course
Hope to help
Giuseppe
