Stat counter for FXS cards
Aug 12th, 2008
I have a couple of FXS cards which allow calls to be sent to a stand alone IVR server. I'm trying to find a way to get a call count, successfule or not, sent to the router bound for the server. Since the only listing of the card is voice-port and typically all connections are viewed using a show voice .... command, I haven't been able to find a command that would show me a count like I normally would see a packet count on an interface.
If someone can point me in the right direction for command that would be great or is there a way to get this information off of the CCM running 4.1?
If you need more info to answer the question just ask.
Jesse Drohen Wed, 08/13/2008 - 15:39
If you are using H323 and don't have other calls traversing this GW "show h323 gateway cause-codes" might give you what you are looking for.
