MPE Presenter Plug-in question
Aug 12th, 2008
can I do an auto install for the presenter plug-in like we can for the outlook plug-in?
something like:
\\path-to-software\setup.exe -admin -silent
so that it can be pushed to end user's pc's for users that do not have admin rights to install software?
Thanks.
ebreniz Mon, 08/18/2008 - 13:22
Try this bug CSCsr62337 Presenter Add-in not recognised with Flash player v9.0.115 and v9.0.124
For users who need to present please do the following:
Uninstall the Flash plugin, instead of Add/Remove programs, use the uninstaller
http://download.macromedia.com/pub/flashplayer/current/uninstall_flash_player.exe
From cmd prompt in the folder with that exe run
"uninstall_flash_player.exe /clean"
Then proceed with the flashplayer9r47_winax.exe (IE) and flashplayer9r47_win.exe (firefox) installations
http://fpdownload.macromedia.com/get/flashplayer/installers/archive/fp9_archive.zip
