Need second fast ethernet on 2620xm router.
Aug 12th, 2008
I am having a heck of a time finding information on this. I have a 2620xm router that only has one ethernet port on it. Is there an expansion I can get that allows me another ethernet port.
I have thus far assumed that all of the WIC cards won't allow me to attach to an ethernet LAN. Thanks, all.
ropethic Fri, 08/15/2008 - 03:43
You can also create a subinterface on the existing fast ethernet and setup a trunk to route the new subnet.
pedro.rocha1 Fri, 08/15/2008 - 04:06
That's what I was going to end up doing, but I guess version 12.2(15)t5 software doesn't support encapsulation? Because I went into the sub-interface of the one ethernet port and it wouldn't take the encapsulation command.
Bernard Manduley Sat, 12/24/2011 - 06:13
You can refer to this guide when picking out WICs and NMs
http://www.cisco.com/en/US/products/hw/routers/ps214/products_tech_note09186a00800ae37f.shtml
You'll notice that there aren't any fast ethernet cards supported in the 2600 router series.
I have a NM-1E in my 2620 and it's the interface connected to my cable modem. It works great and I get full 10 Mbps download speeds and full fast ethernet on my LAN.
Reza Sharifi Sat, 12/24/2011 - 08:54
Tmandule,
Are you sure your router is 2600 series and not 3600 series?  From the same link you provided, the NM-1E is not supported under the 2600 and 2600XM series. Only 3600 series.
Bernard Manduley Tue, 12/27/2011 - 05:40
Reza,
The NM-1E isn't listed in the compatibility chart. I'm just guessing here but it probably is compatible with any of the listed routers. It definitely does work in my 2620.
The modules that won't work are FastEthernet or cards with extra WIC slots, such as NM-1FE2W
