willibr0 Tue, 08/12/2008 - 11:46
You can generate this report with route plan report under route plan in CCM. Change the find option to translation pattern and hit find. After that if you hit the view in file button in the upper right it will open this query in .csv format.
Bryan
rcrumm_2 Tue, 08/12/2008 - 11:50
I did that, but there is nothing on the report for the description. That is what I really need.
It only has a column for route detail. And I do not see where that info would be pulled from.
Any idea
RC
willibr0 Tue, 08/12/2008 - 12:01
When i hit view in file it opens a .csv with the device name, device description, partition, route filter and pattern headings. Does it not do that for you?
Bryan
rcrumm_2 Tue, 08/12/2008 - 12:05
1st I get an error, saying this .asp is different that the .xls.
Then when I do open it, I get the columns and headers, but when i scrll to the translation patters there is nothing in the description column.
RC
