PBR on VRF interface
Aug 12th, 2008
Hi All,
We have a 7600 series router with 12.2(18)SXF4 and we would like to use PBR on a VRF interface and force the traffic comming from that interface to use next-hop to the vrf next-hop address on the same router bypasssing the VRF routing table on this router.Is this possible ? Any help would be really appreciated .
Anantha Subramanian Natarajan
Overall Rating: 2 (1 ratings)
romccallum Thu, 08/14/2008 - 01:26
have you tried applying a route map on the vrf interface and setting the next hop to whatever you want? I dont see why normal PBR wouldnt work here!
anasubra_2 Thu, 08/14/2008 - 02:01
Hi Romccallum,
Not yet amd will be trying to do that .
