Adding a Custom Java Class in CRS 3.5(4)
Aug 12th, 2008
I put a new custom class file on the IVR in C:\Program Files\wfavvid folder. Then I restarted the CRS Engine but when I go into Script Editor to create a new Java Type variable for it I get a "Illegal Type" error. There are other custom class files in this directory that are working so I know the classpath is correct. Any ideas what my problem could be?
Chad Stachowicz Tue, 08/12/2008 - 13:08
  • Silver, 250 points or more
in newer uccx you need to go into the administration under System - > Custom File and move it over to a selected Custom File, then CRS will see it! I imagine it was the same on 3.5(4).
HTH, please rate useful posts
Chad
