On-Hold Ringback on UCM
Answered Question
Using UCM version 5.1.3 - need to know if there is a parameter or timer to set a ringback for callers put on hold. For example, if I put a call on hold and forget about them, after a set time limit (say 2 minutes), my phone rings again reminding me there is a caller on hold. Maybe ringback isn't the correct terminology.
Does this feature exist for version 5.1.3, and if so, where is it set?
robb
Correct Answer by Rob Huffman about 8 years 10 months ago
Hi Robb,
Just to add a note here;
The feature you want is called "Hold Reversion" The bad thing is that this feature is available on CCM 4.2/6.x and not CCM 5.x Have a look;
The Hold Reversion feature alerts a phone user when a held call exceeds a configured time limit. When the held call duration exceeds the limit, Cisco Unified CallManager generates alerts, such as a ring or beep, at the phone to remind the user to handle the call. The held call becomes a reverted call when the hold duration exceeds the configured time limit.
The types of alerts that are generated at the phone for reverted calls depend on the capabilities of the phone device. Cisco Unified Call Manager provides the following alerts when the hold reversion feature activates, depending on the capabilities of the phone and the firmware release that is installed.
The phone rings once or beeps once.
The status line briefly displays "Hold Reversion" for the reverted call at the user phone.
The LED next to the line button flashes continuously on the phone handset, like other alerting operations.
A "wobbling" handset icon displays for a reverted call.
From this CCM 4.2.3 doc;
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_administration_guide_chapter09186a008070e55c.html
This "Hold Reversion" feature is available on CCM 6.X as well!
Hope this helps!
Rob
Overall Rating: 4.5 (3 ratings)
Chad Stachowicz Tue, 08/12/2008 - 13:22
  • Silver, 250 points or more
Of course it exists and the timer is set under the System -> Serivce Parameters -> Call Manager.
I beleive it is under the clusterwide parameters, features.
HTH,
Chad
Correct Answer
Rob Huffman Tue, 08/12/2008 - 13:41
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Robb,
Hope this helps!
Rob
Chad Stachowicz Tue, 08/12/2008 - 14:41
I have only looked and done this feature ona 4.2 and 6.x, good one rob, a Plus 5 for sure!
Chad
Rob Huffman Tue, 08/12/2008 - 14:53
  • Hall of Fame,
    Founding Member
Hi Chad,
Thanks buddy! It's very hard to remember what's what with these versions thats for sure.
Take care,
Rob
Rob Huffman Wed, 08/13/2008 - 05:13
  • Hall of Fame,
    Founding Member
Hi Robb,
You are most welcome my friend :) Glad to be of some small help here.
Take care,
Rob
