Cisco Security Manager 3.2 Pro SP2: Error when performing backup
frekes
I recieve the following error when I attempt to do a backup:
The directory [C:/CSM Admin Folder/] contains space. Backup directory should not have space.Suggestion: If the folder is [Program Files] use [Progra~x]
I'm unsure what this is telling me. Do I need to raise a TAC case?
Many thanks,
Steve
frekes
Update:
WHen performing the same action through the client interface, rather than from the server interface the backup has appeared to work.
Is this a feature?
Needless to say I was able to run a backup.
Steve
lberntss
I think the easiest thing to do would be to rename the back-up folder with a name that doesn't have any spaces in it. i.e. C:/CSM_Admin_Folder/. See if that helps.
-Leif
