Check Latency
Aug 12th, 2008
Hi, What is a way to verify the latency. Suppose I am doing ping one locl machine and it responce 10 ms and one of the machine is located on other location and when I do ping then it shows 100 ms so how may i check and verify that the 100ms latency is abstly correct and it cud nt be less than 100 ms. Thanks
Farrukh Haroon Wed, 08/13/2008 - 11:21
  • Red, 2250 points or more
Have you checked the 'pathping' command which is there with windows by default?
Farrukh
ray_stone Wed, 08/13/2008 - 11:22
Yes I know about Pahping command but yet also I wud like to understand in more details. Thnaks
Farrukh Haroon Wed, 08/13/2008 - 11:25
I don't understand this part of your query that well:
"so how may i check and verify that the 100ms latency is abstly correct and it cud nt be less than 100 ms"
If you don't have faith in one command/tool you can use another. Is this a good enough way to verify? Or you are looking for something else? Something like how we take a 'second opinion' from a doctor :)
Farrukh
