Port address translation in in PIX
Answered Question
Aug 13th, 2008
I'm using pix 525 firewall and i want to add a nat entry to accomplish bellow target.
External users direct port 443 requests to unique IP address 203.xxx.xx.xxx, which the PIX redirects to port 8443.
so, if i add it as:
static (inside,outside) tcp 203.xxx.xx.xxx 443 8443 netmask 0 0
kindly can some one advice will this give what i need as mentioned above.
Correct Answer by Marwan ALshawi about 8 years 2 months ago
it needs clear xlate
and sometimes needs reloading the firewall !!
try it and let me know
Overall Rating: 5 (2 ratings)
Marwan ALshawi Wed, 08/13/2008 - 03:16
this is exactly what u need
only one more thing u need to add
which is the permit access list
for example
access-list 100 permit tcp any host 23.x.x.x eq 443
access-group 100 in interface outside
good luck
please, if helpful rate
samantha.lk Wed, 08/13/2008 - 18:01
Many thanks for your valuble response.
I have already added that access-list antry also, even I forget to mention it there.
But unfortunately still it is not allowing outsiders to come inside through https.
DO i have to restart the firewall or do a clear xlate command inorder to work that?
further, is there any way to view whether this NAT is working? (any show command or something ..) when i do show xlate command
it only display as
Global Local 10.50.x.xx
and no port numbers are showing.
your kind advice is appreciated.
Marwan ALshawi Wed, 08/13/2008 - 18:13
r u using port 8443 as https in ur internal server?
basicly it should look like
static (inside,outside) tcp 203.xxx.xx.xxx https https netmask
unless u have changed the port number
and sure as u mentioned u have to have permit ACL
do have th proper config on the server it self
i mean the default gateway and so on
try show nat ?
and see the available nat commands
also i would recommend u
after changing any NATing to do
clear xlate
if didnt work
reload the firewall
then test the nat again
good luck
please if helpful rate
samantha.lk Wed, 08/13/2008 - 18:44
it was Nice to see your prompt response..
As u think I'm using port 8443 as https in my internal server.
let me expalin bit more about this senario.
previously our company requirment was provide access for outsiders to access this server on port 8443. (same as the servers https port 8443). so i make changes and it was working fine.
Now they wanted outsiders to access it through port 443 and redirecting that trafic as 8443 to the internal server from the PIX.(server side no change)
so what i have done was changed the previous one to one nat as bellow.
OLD- static (inside,outside) tcp 203.xxx.xx.xxx netmask 0 0
NEW- static (inside,outside) tcp 203.xxx.xx.xxx https 8443 netmask 0 0
and provide access-list antry as
access-list 200 line 28 permit tcp any host 203.xxx.xx.xxx eq https
(this is my outside-inbound access list)
kindly mention whether it is really need to do clear xlate? is there any way to only remove a perticular entry?
when i do show nat it doesn't show all natings.(only 2 showing and i have many others also).
Kindly advice.
many thanks for spending your valuble time on this.
Correct Answer
Marwan ALshawi Wed, 08/13/2008 - 18:57
samantha.lk Wed, 08/13/2008 - 22:47
I reloaded the firewall and It is working now!!!
Many thanks for your valuble advices..
