Trunk between PIX and Catalyst switch
Answered Question
Yesterday I got extremely good response from the forum how to create VLANs on PIX, I created the subinterfaces and assigned VLANs to them. I configured IP addresses as well. Did the same on the Cat Switch - created SVI and assined them IP add respectivly. Cat Switch shows its port is trunking properly but I cannot ping from PIX to the Switch and vice versa. Please help.
rvr
Correct Answer by Farrukh Haroon about 8 years 5 months ago
Is it possible for you to post the configuration of the PIX? At least the interface configuration?
And the trunk interface configuration on the switch?
Farrukh
Overall Rating: 5 (1 ratings)
massimiliano.se... Wed, 08/13/2008 - 03:46
In the interface configuration mode did you use the command:
vlan vlan_id
That is did you put the interface in the proper vlan?
Is the encapsulation type on the Catalyst set to 802.1q?
Massimiliano.
I used vlan 10 in subinterface config mode.
I assigned an IP as well. Named the subinterface as TEST and issued no shut. The configuration on the Cat is OK. Encapsulation is dot1q. I have two SVI int vlan 1 and int vlan 10. sh int f1/1 trunk on the Cat shows the post is trunking for VLAN 1 and 10, which is what I want to see.
When I try to ping from the PIX to the Cat, the PIX doesnt know where to go for that IP (in this case IP add of the VLAN 10 SVI on the Cat). The PIX is missing some more configs I think.
rvr
Farrukh Haroon Wed, 08/13/2008 - 04:25
Do the native vlan bit, then do 'show arp' on PIX (and switch) also to see if they are seeing MACs of each other.
Farrukh
Farrukh Haroon Wed, 08/13/2008 - 04:10
Try to set the native vlan of this trunk port (on the switch) same as the vlan you assigned on the PIX sub-interface. I know it makes no sense, but I'm tell you from past experiences(s), so just do it :)
Then check.
Farrukh
Correct Answer
Farrukh Haroon Wed, 08/13/2008 - 05:14
Farrukh
Farrukh Haroon Wed, 08/13/2008 - 05:53
Please add this on the switch:
interface FastEthernet1/1
And then see how it goes. Shut/Unshut the port just in case.
Please send output of 'show interfaces trunk' after this.
Farrukh
Farrukh Haroon Wed, 08/13/2008 - 06:28
Try this (I know this makes no sense for trunk ports once again) but on the switch
int fa 0/1
switch access vlan 10
And try rebooting both the switch and the firewall if possible. You can also try to change the interface/port on the switch.
Farrukh
Farrukh Haroon Wed, 08/13/2008 - 06:34
Also is the port up/up on the PIX if you do 'show interface'. You should also see a route for this subnet when you do 'show route' on the PIX?
Farrukh
No I didn't because I will covert the port from trunk to access and I need this port to carry more than one VLAN. That's my idea to use one Physical port for many VLAN/s on the PIX. On the Switch I will configure several client VLANs that will communicate with the PIX over the trunk. The clients will access their site over VPN (different tunnels) from my network. I am running out of physical ports.
rvr
Farrukh Haroon Wed, 08/13/2008 - 11:32
No this command will not convert.
If you enter this command tough, IT WILL:
switch mode access
Farrukh
Farrukh Haroon Thu, 08/14/2008 - 03:56
Told ya buddy :)
I'm glad you have it working.
However I would really like to know the comments of the routing/switching experts on this forum as to WHY it worked :)
Farrukh
