barcode scanner
Answered Question
Aug 13th, 2008
Can anyone reccomend a good barcode scanner
(pref Wireless)in the UK that doesn't require proprietary software.
Correct Answer by Kid Dynamite about 8 years 7 months ago
The ones I used were the very basic wired ones that used the USB input. Sort of like this -
http://www.barcodestore.co.uk/Barcode-Scanners--Readers-/Best-Selling-Barcode-Scanners--Readers/Decode-X9000/p-70-132-252/#
...but without a power supply. It used the USB for power.. the exact models I used are not on there and I don't recall the names but I think they are all pretty much the same TBH
That site has got PDF's for all the products that tell you everything you need to know though..
Overall Rating: 5 (2 ratings)
silex Wed, 08/13/2008 - 07:59
Is there a particular model you use and like?
I have never had to use one, and would hate to spend money on something that is awkward to use.
Correct Answer
Kid Dynamite Thu, 08/14/2008 - 00:58
Rob Huffman Thu, 08/14/2008 - 05:07
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi David,
Just thought I would throw this in to add to the great info from Kid.
We use the Symbol LS2208 shown @ the link below. This has worked very well for us :)
http://www.barcodestore.co.uk/product.asp?s=5gzgld190391&strParents=&CAT_ID=0&P_ID=166
Hope this helps!
Rob
silex Thu, 08/14/2008 - 05:19
Excellent, thanks, Kid and Rob, just what I was looking for.
