VG224 configuration
Aug 13th, 2008
I have got the VG224 and the CUCM6.1.1, i want the basic configuration on the VG224, and how do i integrate this with the CUCM. if it is gateway how it will be as a MGCP or SCCP and what will be the configuration on the VG....
Please help on this i will be greatful to you.......
Thanks & Regards
Lal Mohammad
lal.mohammad Wed, 08/13/2008 - 05:39
I have already gone through all those links but it does not talk about the integration wiht the CUCM, and there is no configuration for the VG224.
Marwan ALshawi Wed, 08/13/2008 - 05:43
  • Purple, 4500 points or more
  • Community Spotlight Award,
    Best Publication, December 2015
u can configure it as any cisco voice gate way
make the lan interface access port but put it in the vlan number that is voice vlan in ur network
and u can configure it like noraml h323 or ngcp gateway
and define it in the cucm or ccm as a gateway
then included it in ur dial plan through route pattrens route groups and so on
good luck
