HWIC-1FE & 1841
Aug 13th, 2008
I have a cisco 1841 router and i required an additional interface.
When i slot HWIC-1FE card into the router i could not see it when i display the interface or the configuration.
Is the a command to enable it.
Appreciate your help.
Overall Rating: 4.4 (6 ratings)
rkhalil Wed, 08/13/2008 - 08:36
  • Bronze, 100 points or more
You insert the wic when the router is powered down ?.
The IOS req. if you have IPBASE is version 12.4(15)T6 or 12.4(11)XJ3
Raul
(Please rate helpful posts)
rkhalil Thu, 08/14/2008 - 03:47
try upgrade to version 12.4(15)T6 ..
Raul
Richard Burts Thu, 08/14/2008 - 03:55
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Codjo
Raul has correctly identified the problem. To use the card that you got there is a dependency on the version of IOS. The version that you are currently running does not support the card and that is why it does not show up. There is no command in your current version to make it work. You will need a more current version of IOS before that card will work in your router.
Rick
Joseph W. Doherty Thu, 08/14/2008 - 05:44
fyi: for Eric,
Later versions of the software within the same "train" should also provide the necessary support, so 12.4.20T should be an option besides 12.4.15T6.
vineetsha Tue, 03/23/2010 - 05:27
I have the same problem. Just that I have version 12.4(21) on my 1841. The sh diag of the router is as follows:
WIC/HWIC Slot 0:
Unknown WAN daughter card
WIC module not supported/disabled in this slot
Hardware Revision        : 2.0
Top Assy. Part Number    : 800-27737-02
Part Number              : 73-10676-02
Board Revision           : B0
Deviation Number         : 0
Fab Version              : 02
PCB Serial Number        : FOC11291H5C
RMA Test History         : 00
RMA Number               : 0-0-0-0
RMA History              : 00
Product (FRU) Number     : HWIC-1FE
Version Identifier       : V01
CLEI Code                : COUIAFTCAA
Base MAC Address         : 0019.5620.0794
MAC Address block size   : 1
Connector Type           : 01
EEPROM format version 4
EEPROM contents (hex):
   0x00: 04 FF 40 05 3A 41 02 00 C0 46 03 20 00 6C 59 02
   0x10: 82 49 29 B4 02 42 42 30 88 00 00 00 00 02 02 C1
   0x20: 8B 46 4F 43 31 31 32 39 31 48 35 43 03 00 81 00
   0x30: 00 00 00 04 00 CB 92 48 57 49 43 2D 31 46 45 20
   0x40: 20 20 20 20 20 20 20 20 20 89 56 30 31 20 D9 02
   0x50: 40 C1 C6 8A 43 4F 55 49 41 46 54 43 41 41 CF 06
   0x60: 00 19 56 20 07 94 43 00 01 05 01 FF FF FF FF FF
   0x70: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
Help required guys. TY.
Leo Laohoo Tue, 03/23/2010 - 17:39
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
    2017 LAN, Wireless
HWIC-1FE requires the "T" train.  You currently have the plain version.
Don't forget to rate our post.
vineetsha Wed, 03/24/2010 - 01:25
Many thanks for the help.. The problem no longer exists.
Leo Laohoo Wed, 03/24/2010 - 02:19
  • Hall of Fame,
    2017 LAN, Wireless
Thanks for the rating.  Was your problem rectified?  IF so, how?
vineetsha Wed, 03/24/2010 - 03:44
I changed the IOS version to 12.4(24)T1 and the HWIC-1FE card was recognised after the boot.
