RME 4.0.6 device package
Answered Question
Aug 13th, 2008
I have Cisco WS-CBS3020-HPQ, and unable to archive the configuration for this devices. my question is RME 4.0.6 able to manage this device or do I need device package.if so which device package I need to download.
Correct Answer by Joe Clarke about 8 years 8 months ago
Looks like bad credentials in DCR.
Overall Rating: 5 (1 ratings)
Joe Clarke Wed, 08/13/2008 - 08:44
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
This switch is supported in RME 4.0.6 provided you have version 4.1 of the CBS3000 device package loaded.
eliaspaulos Wed, 08/13/2008 - 09:24
I have 3devices like this all failed for the same reason. here is the error I got.
CM0151 PRIMARY RUNNING Config fetch failed for cs00-3d Cause: TELNET: Failed to establish TELNET connection to 10.100.100.1 - Cause: Connection refused. PRIMARY-RUNNING config Fetch Operation failed for TFTP. SSH: Failed to establish SSH connection to 10.100.100. - Cause: Authentication failed on device 3 times. Failed to fetch config using RCP.cwrcp: Copy failed: Connection refused Verify RCP is enabled or not. Failed to fetch config using SCP.com.cisco.nm.lib.cmdsvc.CmdSvcException: Authentication failed Verify SCP is enabled or not. Action: Check if protocol is supported by device and required device package is installed. Check device credentials. Increase timeout value, if required.CM0151 VLAN RUNNING Config fetch failed for cs319-3s Cause: TELNET: Failed to establish TELNET connection to 10.16.100.111 - Cause: Connection refused. VLAN Config fetch is not supported using TFTP.SSH: Failed to establish SSH connection to 10.100.100.1 - Cause: Authentication failed on device 3 times. VLAN Config fetch is not supported using RCP.VLAN Config fetch is not supported using SCP. Action: Check if protocol is supported by device and required device package is installed. Check device credentials. Increase timeout value, if required.
Correct Answer
Joe Clarke Wed, 08/13/2008 - 09:25
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
eliaspaulos Wed, 08/13/2008 - 10:19
thank you so much J. I have found the error on credentials. it's working now!!!!!
