Higher volume = Echo ?!
Aug 13th, 2008
Hi there !
People here are complaining about hearing the voice too low, but if they configure the volume of the phone higher, they say that they can hear they're own voices (ECHO?!)...
Those are (7941G) with plantronics hearset...
Whitch is the best way of dealing with it ? Is there any configuration in 7941 or must QoS solve this ?
<7941G>---<LAN>---<GW>---<PBX>---<Analog_Phone>
Thanks.
Andrei.
Daniele Giordano Thu, 08/14/2008 - 09:53
Telephone networks can experience two types of echo: acoustic echo and electrical echo.
Acoustic echo frequently occurs with speakerphones, when the received voice on the speaker
excites the microphone and travels back to the speaker. Electrical echo occurs when there is an
electrical inconsistency in the telephony circuits. This electrical inconsistency is called
impedance mismatch.
If the lines have a good impedance match, the hybrid is considered balanced, with little or no
reflected energy. However, if the hybrid is inadequately balanced, and a portion of the transmit
voice is reflected back toward the receive side, echo results.
Some form of echo is always present. However, echo can become a problem under the
following conditions:
The magnitude or loudness of the echo is high.
The delay time between when you speak and when you hear your voice reflected is
significant.
The listener hears the speaker twice.
The two components of echo are loudness and delay. Reducing either component reduces
overall echo. When a user experiences delay, the conversation can get choppy, and the words of
the participants sometimes overlap.
There are two ways to solve an echo problem in your telephone network:
Echo suppression
Echo cancellation
The echo suppressor works by transmitting speech in the forward direction and prohibiting
audio in the return direction. The echo suppressor essentially breaks the return transmission
path. This solution works sufficiently for voice transmission. However, for full-duplex modem
connections, the action of the echo suppressor prevents communication. Therefore, when
modems handshake, the answering modem returns a tone of 2025 Hz to the calling modem,
which serves to disable the echo suppressors along the transmission path.
Echo suppression has shortcomings in addressing certain echo conflict situations. Echo
cancellation is a more sophisticated method of eliminating echo.
Rather than breaking or attenuating the return path (as in echo suppression), echo cancellation
uses a special circuit to build a mathematical model of the transmitted speech pattern and
subtract it from the return path.
You must configure the voice-port of your gateway:
echo-cancel enable and echo-cancel coverage are used to activate echo cancellation;
non-linear is used to activate echo suppression;
Check POTS/PSTN impedence too.
On LAN use only switch, not hub. Check the latency.
