Login softkey in IPphones
Aug 13th, 2008
I am configuring Call-Block patterns in CME4.3 with 7911 and 7941 phonnes
The problem is that the login softkey does not appear ine the phones for call-block overriding
Some one can tell me what can I do to make the phone display that softkey.
Regards.
Jaime Valencia Wed, 08/13/2008 - 08:59
  • Cisco Employee,
  • Hall of Fame,
    2011
configure the ephone-template and assign the softkey to onhook state, then apply it to the ephones
java
if this helps, please rate
abdeljaoued Wed, 08/13/2008 - 09:34
I configured the ephone-template with the "softkeys idle login" command and it does not work (only non configurable keys are displayed).
I dont know how to assign the softkey to onhook state. Normally the login key work in the idle state of the phone no?
rfovrtega Fri, 11/07/2008 - 17:10
I'm having trouble about it too, and here's what I've done to make the login softkey active.
1. Make sure that the login softkey is activated in your ephone-template under idle state.
e.g. ephone-template 1
softkey idle Newcall Login
2. Make sure that the particular ephone you what to be login has a pin.
e.g. ephone 3
pin 1234
3. Finally, the most important thing, and also I overlooked that's why we cannot activate the login key is that we should put a login timeout under telephony services.
e.g. telephony services
login timeout 240
