VPN Client TCP connection to IOS router
Answered Question
Aug 13th, 2008
I am trying to get a VPN client to connect via TCP to a router. I currently have the router set up (and working) using a UDP-VPN. Unfortunately one of the sites I visit wont allow VPN traffic out of their firewall. I have looked all over the Cisco site and am unable to find info on configuring IOS to accept TCP-VPN connections. I would like to change the port to tcp 80, so my VPN traffic just looks like standard internet browsing to my clients firewall. Any links/pointer would be greatly appreciated.
Thanks in advance!
-Joe
Overall Rating: 5 (1 ratings)
joe.morrison Wed, 08/13/2008 - 17:16
Kudos to you Ferrukh!!! Thanks for the quick response!
The cTCP command solved my problem and now I can VPN from anywhere! WoooHoooo!!! I have been looking for this command off&on for about 4 months... I should have posted long ago.
Thanks for your help!
-Joe
Farrukh Haroon Wed, 08/13/2008 - 18:39
  • Red, 2250 points or more
No problem at all Joe, glad you have it working :)
