Verint call recording issues with transfer due to different RouterCallKey
Aug 13th, 2008
I'm running into an issue with continuous call recording for Verint.
Scenario - call comes in, agent handles call, transfers to supervisor queue, caller talks to supervisor.
Verint should show this as continuous call with segment 1 and 2. However, I see two calls.
Verint says this is because RouterCallKey is different for these calls, which I confirmed.
Did anyone run into this issue? Any suggestions on how to modifying ICM scripting so calls transferred to queue will retain the same RouterCallKey?
david.macias Wed, 08/13/2008 - 13:01
  • Blue, 1500 points or more
Are you sure the second transfer has a different rck? Assuming UCCE the transferred call should have the same rck. What is your environment like (e.g. UCM, CVP, etc)?
Thank you,
david
