Two ACS Server
Aug 13th, 2008
My setup is woking great with One ACS Server, If I have another ACS Server as secondary then what additional configuration required on the devices and what parameters required for time-out
With IE 6.0 / 7.0 the ACS Console gets hang, currently working with FIREFox...
Is there special requirement for IE. ( I guess JAVA makes the issue ) Any suggestion on this....
Collin Clark Thu, 08/14/2008 - 12:31
You can simply add another server.
<font size="2"></p><p>ssh-test(config)#tacacs-server host 1.1.1.1</p><p>ssh-test(config)#tacacs-server host 1.1.1.2</p><p>ssh-test(config)#do sh run | i tacacs</p><p>tacacs-server host 1.1.1.1</p><p>tacacs-server host 1.1.1.2</font>
You can also configure the time out for TACACs.
<font size="2"></p><p>ssh-test(config)#tacacs-server ?</p><p></p><p> timeout           Time to wait for a TACACS server to reply</p><p></p><p>ssh-test(config)#tacacs-server timeout ?</p><p></p><p>  <1-1000>  Wait time (default 5 seconds)</p><p></font>
Hope that helps.
