workgroup bridge passing WDS info
Aug 13th, 2008
Does anyone know if a workgroup bridge/non-root bridge will pass information to back and forth to a WAP that is downstream from a non-root bridge through a switch connected to the non-root bridge. I have verified network connectivity between all devices and the WDS. The client WAP indicates WDS not discovered with the command-->sh wlc ap. I suspect the bridge does not pass the traffic to and from the WDS to the client WAP. Any hints are appreciated
WDS not discovered
beabrams Thu, 08/14/2008 - 03:56
I dont believe you can do this.... for instance bridge on 1 radio and use the other radios for clients (but that it needs WDS or wlccp commands)... if I understand you correctly.
stickhg Thu, 08/14/2008 - 04:37
I have attached a network diagram. Maybe this will help you understand. The WAP that does not discover the WDS has station-role root for a setting. The config this WAP worked at a client before. The only difference is there is a bridge between it and the WDS. Is there some limitation to the bridge that is stopping the WAP from discovering the WDS or do I need to add configuration lines to the root or non-root bridge to make this work. What is you reason you believe this will not work?
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
