how to use CME 4.3 overide-codes on a IP Phone
Aug 13th, 2008
Hi I am trying to implement after-hours block to international call after hours.
after-hours block pattern 26 9011
after-hours day mon 19:00 07:00
after-hours override-code 1234
I try to go to a ip-phone to use it after 1900 but the login softkey is disabled. I have tried to configure a new ephone-template to the phone with the login only softkey and still it is disabled.
Can anyone shed some light how to enable this Login softkey to test the after-hours over-ride code?
thanks
