CME Expansion
Answered Question
Aug 13th, 2008
Quick Q for the Guru's out there.
If I have a CME chassis that is maxed out with the number of ephones it can have (52 on a 2821 for example) and I needed to add more phones, couldn't i just add another Chassis with a different Extension range and have dial peers pointing to each other?
or am I stuck upgrading the chassis to a much larger (read more expensive) system?
Correct Answer by don-sullivan about 8 years 6 months ago
In short yes without upgrading the chassis. If using physical IP phones you'd have to manually set your TFTP server. If using softphones you have to set TFTP server anyway.
Overall Rating: 5 (1 ratings)
Correct Answer
don-sullivan Thu, 08/14/2008 - 11:41
Jesse Drohen Thu, 08/14/2008 - 14:06
If feasible, creating a different voice vlan with a different option 150 for the new phones you could point them to the second CME box so that you don't have to touch every phone.
steven.wilson Fri, 08/15/2008 - 08:02
You can add another CME. It would need to be on another subnet and have a separate DHCP scope too. If you have QoS on the LAN, you will need to extend it to the new Voice LAN too.
