Tunnel going UP & down
Aug 13th, 2008
  • Silver, 250 points or more
I often get this message once in every 5min. Tunnel will be up for 5mins & can to reach the remote host up to 5 min. & then disconnects. what is causing the issues to make this happen.
Group = x.x.x.x, IP = x.x.x.x, removing peere from the correlator table failed, no match!
Group = x.x.x.x, IP = x.x.x.x, QM FSM error (P2 struct &0xcb7c1558, mess id 0x7aa95d3)!
Group = x.x.x.x, IP = x.x.x.x, Rejecting IPSec tunnel: no matching crypto map entry for remote proxy 0.0.0.0/0.0.0.0/1/0 local proxy 0.0.0.0/0.0.0.0/1/0 on interface outside
Group = x.x.x.x, IP = x.x.x.x, PHASE 1 COMPLETED
Farrukh Haroon Wed, 08/13/2008 - 18:56
  • Red, 2250 points or more
Are you crypto ACLs mirror images (opposite) on both sides? Are you using any any for Crypto ACL? If possible post here.
Seems something to do with Phase 2 Parameters.
e.g. PFS group mismatch, Crypto ACL etc.
Farrukh
Anand Narayana Fri, 08/15/2008 - 09:05
It was actually the clients ACL entry mismatch which made the vpn tunnel bumping up & down.
Farrukh Haroon Fri, 08/15/2008 - 10:07
Yup its usually the ACL or PFS mismatch with Phase 2. Anyway its great to know you have it working now :)
Farrukh
